mfaust
Jul 05, 2020Aspirant
Orbi and Nest
Hi, thanks in advance for any help. I have an RBR 40 router setup with 4 satelittes throughout our house. We have been having issues with our Nest cameras, which have been intermitently losing c...
Jul 05, 2020Guru - Experienced User
Orbi does broadcast 1 SSID, it's your camera who is detecting each of the signals from the RBS and RBR and displaying them separately. Try turning OFF the RBS leaving the RBR online and then set up your camera.
- mfaustJul 06, 2020Aspirant
Thanks FURRYe38. Some answers below:
Firmware V2.5.1.16
The router is connected to an AliceOne box - Its made by Sagecom - model DGCI384. After a bunch of back and forth with the ISP, I was finally able to get them to just use the box as a modem and let me use the Orbi as the router.
The RBS that was the closest to the problematic cameras (Satellite-3) was less than 10 feet and it was daisy chained to another satelite with less than 30 feet distance between each.
I went ahead and just removed that satelite completely and a few interesting things happened:
For a few minutes in the network map, it showed multiple instances of another satellite (Satellite-4). Also, I started watching the cameras that are having issues in the list of attached devices. When they lose the connection, it says they are connected to "Orbi Satellite" with no number after it for a few seconds and then it reconnects to a numbered satelitte.
- FURRYe38Jul 06, 2020Guru - Experienced User
The RBS in the closet would not be recommended. 10 feet is too close if thats the distance between it and the RBR.
Did you reboot the RBR after turning OFF the RBS and then let the cameras connect to the RBR alone and see if the RBS status on the RBRs web page shows disconnected?
Has a factory reset and setup from scratch been performed since last update?
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
