mfaust
Jul 05, 2020Aspirant
Orbi and Nest
Hi, thanks in advance for any help. I have an RBR 40 router setup with 4 satelittes throughout our house. We have been having issues with our Nest cameras, which have been intermitently losing c...
sarwatkazmi
Mar 07, 2022Aspirant
mfaust wrote:Hi, thanks in advance for any help.
I have an RBR 40 router setup with 4 satelittes throughout our house. We have been having issues with our Nest cameras, which have been intermitently losing connectivity.
After multiple attempts to diagnose with our ISP and with Nest, the folks at Nest believe the issue is with the broadcast from the Orbi.
Specifically, when I reset a camera to factory settings and then go to add it to our network, there are somewhere between 7 and 9 listings for our network (all with the same name).
As I understand it, the Orbi should just be broadcasting one SSID, so they believe there is something in the broadcast that is causing confusion for the camera and that it keeps losing connections as it tries to change the connection.
Has anyone had any similar issues or any suggestions for what might be causing this?
Thanks!
same issue i am facing . please help me i shall be very thank full to you..
CrimpOn
Mar 07, 2022Guru - Experienced User
What is the model of Nest camera? Where do these multiple names appear? (Nest app?)
