johnh53
Feb 27, 2018Aspirant
Orbi and Netflix
My Orbi system has been working fine to stream Netflix programmes on my SmartTV until a few days ago, when I started receiving a message saying that Netflix have detected that I am using an "unblocke...
Feb 27, 2018Guru - Experienced User
What is the Mfr and model# of the ISP modem? Built in router by chance? if so, then this either needs to be bridged fully and let the Orbi router be the main router, or if the modem can't be bridged, use the modems DMZ for the IP address the Orbi router gets from the Modem. You maybe in a double NAT condition.
johnh53
Feb 28, 2018Aspirant
Thanks for the response, but I'm afraid I'm an elderly techo-virgin and don't really understand your reply, and wouldn't know how to carry out the changes you suggest. I'm in UK , my ISP is SKY and the modem they supply is their standard one.
Any chance of an idiot's guide to sorting out this problem?!!
- tsigFeb 28, 2018Luminary
If you were able to plug directly into your ISP's modem, then it is still acting as a router, correct? If so, your Orbi needs to be set up as an access point only, not a router. Check the instructions for putting it in AP mode.
- johnh53Feb 28, 2018Aspirant
Thanks for the suggestion. I've actually managed to surprise myself and change the Orbi router to AP Mode. This hasn't solved the problem however - I still cannot stream anything from Netflix on my Smart TV (I can on my desktop computer which is situated right next to the modem and Orbi router - but the Smart TV is in a separate room, hence the need for the Orbi system). The message from Netflix says that they have "detected" that I am using a unblocker (I'm not) or a proxy (I'm not). I get the feeling that whatever Netflix are using to do their detecting is a bit over sensitive and finding issues where there aren't any - after all, it all worked like a dream until a few days ago. And the Netflix helpline is particularly unhelpful. Looks like they will be losing a customer.
Maybe try to forget the network on your TV and rejoin?
- FURRYe38Feb 28, 2018Guru - Experienced User
Reason for asking for modem Manufacturer and model# is to help us identify if your modem has a built in router or not. Having a modem/router combo can cause problems with external connected routers like the Orbi router.
Looks like you got the Orbi system set up so you may have a modem router combo.
johnh53wrote:Thanks for the response, but I'm afraid I'm an elderly techo-virgin and don't really understand your reply, and wouldn't know how to carry out the changes you suggest. I'm in UK , my ISP is SKY and the modem they supply is their standard one.
