phydauxs
Aug 04, 2017Tutor
Orbi and Netgear EX6200 / EX6100 range extenders connected to security camers
I have just purchased the Orbi system. Prior to the Orbi I had two Netgear EX6200s and one EX6100 range extender. One EX6200 and the EX6100 have security cameras connected to them (Logitech alert) and worked perfectly connecting to the other EX6200 which was connected wirelessly to my router so I could view the camera feed on my computer. I have replaced one EX6200 with the Orbi satellite. I have reset the one remaining EX6200 and the EX6100 and connected them to the Orbi satellite. Logic tells me that the cameras should work as before but they dont. I get no video feed as before. Has anyone got any suggestions on what the problem might be?
- DarrenMSr. NETGEAR Moderator
Hello Phydauxs
Are the cameras still on the extender or they connected to the orbi network? Did you reserve the IP address of the cameras on orbi?
DarrenM
- phydauxsTutor
Thanks for the reply Darren. Firstly, cameras are connected to EX6200 Extender. I havent reserved IP address for anything (not sure how to do it if it needs to be done). Just an update since last week. I have managed to get the feed from the cameras on devices that are connected wirelessly to the Orbi ie my phone and Surface pro. What I havent been able to do is get the feed on my desktop computer that is connected to modem via ethernet (Orbi is connected to modem via cable). The modem includes a wireless router and I have turned the wireless off so that it doesnt conflict with the Orbi. The modem seems to be sending the signal to the orbi but not the other way around as I have two other cameras connected to modem via POE and they are appearing on wireless devices via Orbi. I imagine that its just a setting on the modem or Orbi that needs to be enabled or disabled but have no idea what that might be. Any further thoughts?
- st_shawMaster
phydauxsBased on your description, you have two devices acting as routers: your modem and the Orbi. This would explain why your desktop (connected to modem) cannot see anything connectied to Orbi. If Orbi is in rotuer mode, it will treat anything connected to your modem as being on the Internet and the firewall will block access to devices on the Orbi WiFI.
You should set Orbi into Access Point mode, then all devices behind your modem will be visible to each other. (Or you could bridge your modem, but this might be more complicated.)
