Jhurst
Jun 25, 2018Follower
Orbi and network switch
Using unmanaged switch connected to orbi port. Need to add another. Can I use another port on orbi or daisy chain switches instead?
Jun 25, 2018Guru - Experienced User
I would daisy chain the switches then put satellite at the end of the last switch. Have this my self. two switches in between the router and satellite. Working well.
