sabrinamane
Apr 13, 2023Guide
Orbi and new Firmware is a nightmare
Since around 2 weeks I have automatic new firmware installed to my Orbi RBR50 and 2 satellites. 2 weeks of nightmare where internet stop working in the middle of the day due to that. Then. The day aft...
sabrinamane
Apr 13, 2023Guide
Not sure why I should upload manually the FW if this is my main issue? All the cuts are coming from the fact that there is an automatic push for last FW installation. This can be 3 times per day those days. Am just looking for a simple option where I can enable the automatic installation
Apr 13, 2023Guru - Experienced User
Not currently on Orbi AC. There is on Orbi AX systems.
Only one push will be seen. If your having problems then a factory reset maybe needed along with manually loading FW files on the RBS and RBR using a wired PC.
