rh00
Mar 17, 2018Tutor
Orbi and New Nest Hello
Just replaced Ring Pro doorbell with Nest Hello doorbell. Then found out it's not compatible with most of the Orbi products! Why won't Orbi work with Nest and is there an immediate fix coming our way...
rh00
Mar 19, 2018Tutor
Thanks for your suggestions. Apparenly the new Nest Hello and several of the Nest Cameras so not work well with mesh wifi systems and Orbi is one of them. I've talked to very senior tech support at Nest and they seem to be looking to Netgear for a fix. I hope they colloborate and get this fixed for the long haul.
The suggested fix does not repair the issue with Nest Hello but may with some fo the other products. Thanks again!
Mar 19, 2018Guru - Experienced User
At least it's known to them and I'm sure they will work with NG to get it fixed.
Good Luck.
