rh00
Mar 18, 2018Tutor
Orbi and New Nest Hello
Just replaced Ring Pro doorbell with Nest Hello doorbell. Then found out it's not compatible with most of the Orbi products! Why won't Orbi work with Nest and is there an immediate fix coming our way...
Eric90i
Apr 02, 2018Star
I have and the best hello working with the Orbi system. Connected just fine (from what I can tell) system is RBR50 and RBS50. Firmware 2.1.2.18. MIMO off and beamforming off.
Factory reset the hello and give it another try with those two settings off. I had to power cycle the satellite and do a factory reset of the hello during my install due to some initial setup issues because the breaker I had off for installation killed power to the RBR50.
It’s been about a week now working fine
