rh00
Mar 17, 2018Tutor
Orbi and New Nest Hello
Just replaced Ring Pro doorbell with Nest Hello doorbell. Then found out it's not compatible with most of the Orbi products! Why won't Orbi work with Nest and is there an immediate fix coming our way...
gtpinoy
Jun 19, 2018Aspirant
Had no issues with any Nest Products, including the Nest Hello, prior to updating Firmware to V2.1.4.16. Nest Hello is now having issues. Attempting to downgrade to Firmware V2.1.2.18 to see if it helps. I wish I noted what my previous Firmware was prior to updating.
gtpinoy
Downgraded to V2.1.2.18. Factory Reset Nest Hello and now Nest Hello can't even establish a Wi-Fi Connection.
- gtpinoyJun 24, 2018AspirantSetup a totally separate WIFI using previous Apple Extreme Router. Reset Nest Hello (by turning off the breaker). Established a WiFi connection to the Apple Exterme Router. Placed on that WiFi connection for about 12 hours. Went back to the Netgear Orbi WiFi and has been working for about 30 hours with no issues. Running 2.1.2.18 Firmware on both Orbi Router and Orbi Satellite. Not sure what exactly resolved the issue.
