rh00
Mar 17, 2018Tutor
Orbi and New Nest Hello
Just replaced Ring Pro doorbell with Nest Hello doorbell. Then found out it's not compatible with most of the Orbi products! Why won't Orbi work with Nest and is there an immediate fix coming our way...
gtpinoy
Jun 19, 2018Aspirant
Downgraded to V2.1.2.18. Factory Reset Nest Hello and now Nest Hello can't even establish a Wi-Fi Connection.
gtpinoy
Jun 24, 2018Aspirant
Setup a totally separate WIFI using previous Apple Extreme Router. Reset Nest Hello (by turning off the breaker). Established a WiFi connection to the Apple Exterme Router. Placed on that WiFi connection for about 12 hours. Went back to the Netgear Orbi WiFi and has been working for about 30 hours with no issues. Running 2.1.2.18 Firmware on both Orbi Router and Orbi Satellite. Not sure what exactly resolved the issue.
