StanHawk
Oct 01, 2016Aspirant
Orbi and Nighthawk
Is there a way to hang an Orbi system on an existing Nighthawk1900 to get the benefits of both?
- Oct 01, 2016
Yes, you can. Technically, the guest network will share the same Wi-Fi channel as the main, secured network but the Nighthawk will keep the guest traffic isolated.
StanHawk
Can I continue to use the guest network feature of the nighthawk as a separate wifi channel and use the main secured nighthawk network and the orbi using the same SSID, for example "xnet", for both wired and wireless?
TheEther
Oct 01, 2016Guru
