mkonoff
Jun 10, 2020Follower
Orbi and OpenDNS
I have xfinity internet service. Their DNS are hard coded into their devices, cannot be changed (that I'm aware of). I used Netgear with OpenDNS a number of years ago and REALLY liked it. I though...
Jun 10, 2020Guru - Experienced User
You can change DNS settting on the Orbi RBR and it will use those DNS addresses.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too? Built in router here by chance? If so, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
