Rusty123
Feb 10, 2018Initiate
Orbi and OpenVPN: cannot resolve computer name
I have OpenVPN succussfully setup on my Orbi router, and I can connect to my home network successfully using my iPad/VPN. However, when I then try to connect to a computer on my home network using t...
- Feb 10, 2018
I've found it difficult, if not impossible, to get name resolution to work on the iPad over VPN. The other problem is getting the iPad to use the DNS on your LAN and to use the correct search domain.
I just set my RDP servers with a static reserved LAN IP and connect based on the IP.
I use "Jump Desktop" on the iPad, which I would recommend. Jump lets you create a config for each server, and store the IP address in the config. That way you can effectively connect by name.
st_shaw
Feb 10, 2018Master
Rusty123
Feb 11, 2018Initiate
Good to know that this is an expected issue, and not a bad configuration on my part. I enabled a static IP on my RDP server, and that appears to be a good solution. Thanks all!
