MightyT
Aug 23, 2016Star
Orbi and other Routers
Does the Orbi Satellite work with other Netgear AC Routers?
- Aug 24, 2016
No.
You would need the Orbi router to have a wired connection to the R6300 using Ethernet if you want to use both R6300 and the Orbi and put one of the Orbi router or R6300 in access point mode.
The Orbi Satellite connects to the Orbi router only.
DarrenM
Aug 23, 2016Sr. NETGEAR Moderator
Hello MightyT
Can you be more specific with the question? Are you asking if you can connect the orbi to existing routers?
DarrenM
- MightyTAug 23, 2016Star
Yes, my NETGEAR R6300 Router
- DarrenMAug 24, 2016Sr. NETGEAR Moderator
Hello MightyT
Yes you can either use orbi as your main router and connect the R6300 to it and make it a access point or you can connect the orbi to the R6300 and make it a access point.
DarrenM
- MightyTAug 24, 2016Star
OK, so it sounds like I can continue to use my NETGEAR R6300 Router downstairs and set up an Orbi Satelite upstairs and get the greater coverage upstairs I am looking for as if I have to Orbi's.
Thanks!
Tony
