MightyT
Aug 23, 2016Star
Orbi and other Routers
Does the Orbi Satellite work with other Netgear AC Routers?
- Aug 24, 2016
No.
You would need the Orbi router to have a wired connection to the R6300 using Ethernet if you want to use both R6300 and the Orbi and put one of the Orbi router or R6300 in access point mode.
The Orbi Satellite connects to the Orbi router only.
mdgm-ntgr
Aug 24, 2016NETGEAR Employee Retired
No.
sapaulsen
Aug 31, 2016Aspirant
so does that mean that if I put the Orbi router in AP mode, it takes on the IP addressing scheme of my router which is handingout 192.168.0.x IP addresses. I want to make sure that the Orbi is on the same IP address network as all my devices on my network. Please confirm is that is correct.
thanks!
- DarrenMSep 02, 2016Sr. NETGEAR Moderator
Hello sapaulsen
Yes if in AP mode the main router it is connected to would handle the DHCP and assign the IP address.
DarrenM
