bajames's avatar
bajames
Follower
Jul 25, 2018
Orbi and restricting ports
Hi - Looking at the ORBI system and maybe the RBK50.
Want to find out if you can ALLOW access to particular port ranges.
I found a manual that seems to say I can BLOCK ranges but I want to block everything EXCEPT certain ranges.
E.g. Only allow, say, TCP 80, 20, 21, 443 and some others and then UDP 20000 to 20100 and UDP 45000 to 64000.
Is that possible?
JB
1 Reply
  • FURRYe38's avatar
    Ports are already blocked, it's when you use Port configurations that you may choose to open them up and use them...
