Rikerrock
Apr 27, 2019Tutor
Orbi and Samsung Robovac can only do 2.4ghz
I have a orbi system I bought from costco to replace an open mesh system because I needed some more parental controls etc. The open mesh allowed me to assign several ssids (up to four) and choose if...
SimonBelgium
Apr 28, 2019Guide
My Samsung Robovac had no problem connecting to my Orbi. Just make sure it's close to the base station when you're setting it up.
Rikerrock
Apr 28, 2019Tutor
Which robovac? I've got a satelite about 15 ft from the vac and a total of 5 orbi units in my house. Is it poss that I have too many orbi's?
The vac can find the ssid?
- michaelkenwardApr 29, 2019Guru - Experienced User
Maybe the "base station" bit that SimonBelgium mentioned is the key to it.
