Rikerrock
Apr 27, 2019Tutor
Orbi and Samsung Robovac can only do 2.4ghz
I have a orbi system I bought from costco to replace an open mesh system because I needed some more parental controls etc. The open mesh allowed me to assign several ssids (up to four) and choose if...
Apr 29, 2019Guru - Experienced User
Users can temporatily disable the 5Ghz SSID Under Advanced Tab/Advanced Settings/Wireless Settings on the RBR while they get there 2.4Ghz devices connected to Orbil. Afterwards, just re-enabled the 5Ghz SSID.
