Cajigasjd
Nov 18, 2018Follower
Orbi and satilite go offline daily
Model RBR20 filmware 2.2.1.210 WiFi Connection goes off daily. I need to reboot it via app to get it back online. Please help!
Nov 19, 2018Guru - Experienced User
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
