Cajigasjd
Nov 18, 2018Follower
Orbi and satilite go offline daily
Model RBR20 filmware 2.2.1.210 WiFi Connection goes off daily. I need to reboot it via app to get it back online. Please help!
duanemusser
Mar 07, 2019Aspirant
I have had a similar problem. My orbi was great for about 95 days. now, i have to reboot it daily. My Asus would do this automatically. It is annoying and frustrating.
- FURRYe38Mar 08, 2019Guru - Experienced User
What model Orbi do you have?
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using?Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
duanemusser wrote:
I have had a similar problem. My orbi was great for about 95 days. now, i have to reboot it daily. My Asus would do this automatically. It is annoying and frustrating. - Blanca_OMar 10, 2019NETGEAR Employee Retired
Hi duanemusser
Do you have the latest firmware (v2.3.0.32) installed? If not, please update the firmware and let us know of the result.
Blanca
Community Team- duanemusserMar 10, 2019AspirantBlanca,
I do have the latest firmware.
As far as the previous suggestions, my signal inside is fine. It keeps dropping connection to the internet. My fiber modem is working fine.
Unless my ISP started enforcing DHCP expiration, I don't know what else would case it to stop connecting.- Chuck_MMar 10, 2019Mentor
duanemusser wrote:
Blanca,
I do have the latest firmware..I always question when people say this without specifying an actual version number.
- duanemusserMar 11, 2019AspirantI looked again and I have FW V2.2.1.210. The firmware check says it is the latest version available.
I also noticed that RBR40 is not in the options above. Am I on the correct forum?- FURRYe38Mar 12, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?Yes.
You can try the new FW update to see if it helps you out:
You need to load the satellite first to v32, download v212 to the RBR40 first, then upgrade to v28. Manualy download the files and manually upgrade the FW using the RBRs UI. I would factory reset and setup from scratch both units after FW has been upgraded.
- FURRYe38Mar 11, 2019Guru - Experienced User
