Cajigasjd
Nov 18, 2018Follower
Orbi and satilite go offline daily
Model RBR20 filmware 2.2.1.210 WiFi Connection goes off daily. I need to reboot it via app to get it back online. Please help!
duanemusser
Mar 07, 2019Aspirant
I have had a similar problem. My orbi was great for about 95 days. now, i have to reboot it daily. My Asus would do this automatically. It is annoying and frustrating.
Mar 08, 2019Guru - Experienced User
What model Orbi do you have?
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
What WPA security modes are you using?
Try enabling Beamforming and MIMO. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
