matt2047
May 23, 2019Aspirant
Orbi and Screen Sharing (Screens for Mac)
Hi All, We have just installed the Orbi mesh system at our church. Everything works great -- except for screen sharing. Everything is updated on the Orbi (router is running V2.3.1.60). ...
- May 23, 2019
With Orbi in AP mode, one would guess you have another NAT router in front - this is where you have to configure the port forwarding (ideally with MAC<->IP reservations on the DHCP server). The Orbi is not involved - only doing [W]LAN Layer 2 communications. FMI: https://userguide.screensconnect.com/settings/manual-configuration
schumaku
May 23, 2019Guru - Experienced User
- matt2047May 24, 2019Aspirant
Thanks, that was it. I logged into our AT&T modem gateway, and set the machine in question into the appropriate DMZ settings, etc.
Appreciate it!
