Loxley
Jul 23, 2017Guide
ORBI and SONOS - FW V1.12.0.18 does not work
iOS devices cannot connect to SONOS with a Boost wired direct to an Orbi router with the new firmware for Orbi - V1.12.0.18. Macs and PCs can connect. Has anyone else experienced this problem and ...
timch
Jul 23, 2017Luminary
I have Sonos working perfectly with 12.0.18 using a Boost wired directly to the Orbi router. Sonos can sometimes have a problem with resetting IP addresses so I would advise setting up your Orbi network then removing the power to all your Sonos devices and then powering up starting with your Boost. Allow that a few minutes before switching on the ZPs. I am assuming in this that your basic Orbi setup is correct. Just to check, I assume that if it is set as a router that the modem is not routing. Also, I assume the Boost is connected to the router or the satellite.
Loxley
Jul 23, 2017Guide
Thanks for the reply Timch.
My system is connected as you set out in your note. I have restarted from the ground up (Boost then other Sonos units) but I still don't get a working system under iOS using the new firmware. Everything works using an HP laptop, a MacBook Air and an iMac - it just seems to be iPhones and iPads that cannot connect. If I revert to the previous firmware, everything works, including iOS devices.
For what it's worth, I have also reserved the IP addresses of all the Sonos units.
