treherne
May 21, 2017Aspirant
Orbi and Sonos
Have just upgraded to Netgear Orbi having read its best reviews. Had not unfortunately appreciated the issues with Sonos some appear to be having. I have had sonos with one speaker wired and the othe...
- May 22, 2017
Have you set the Orbi in AP mode? If it is still in router mode then the Orbi network will be separate to the BT Homehub network and therefore there will be no means to talk to the Sonos system from the Orbi Wifi. I had no problem running this setup as far as the Orbi and Sonos were concerned; my issues were all with the Smart Hub which I have now consigned to my spares box.
loomis1975
May 21, 2017Luminary
Maybe you have already thought of this and done it, but worth asking.
Have you checked the wireless channels the Orbi and the Sonos are using on 2.4 ghz, and changed them to make sure they are well seperated, like 1 and 11?
