djw1203's avatar
djw1203
Follower
Dec 05, 2018
ORBI and Switch
We are looking to use an Orbi router and 24 port switch for the wired computers. Is there a switch model that would be best to use with the Orbi?
  • FURRYe38's avatar
    Dec 05, 2018
    Most any model will be good. Make sure it's NON managed and doesn't have any Green Ethernet features. If you happen to get a Managed switch, besure to disable ALL IGMP Protocols. Orbi and IGMP on managed switches don't seem to get along well.
    I've tested NG, D-Link and HP switches. I have a 24 port HP switch as my main LAN switch.
