Tjharris6
Jul 30, 2019Guide
Orbi and switch
I’m a little confused about the Ethernet backhaul. I need to hookup 2 devices a computer and camera system to the Ethernet port on the router is this possible? Do I need a unmanaged switch?
Jul 30, 2019Guru - Experienced User
If you use a managed switch, be sure to disable ALL IGMP protocols.
For managed switches, review NGs GS105/108 series.
Tjharris6 wrote:I’m a little confused about the Ethernet backhaul. I need to hookup 2 devices a computer and camera system to the Ethernet port on the router is this possible? Do I need a unmanaged switch?
