Brettmc
Feb 02, 2017Follower
Orbi and Synology Web Interface
Hello, Just installed my Orbi and it works great! One problem I do have now is that I can no longer use the Java-based web management of my two synology servers. The servers mount just fine on m...
Hansyeung
May 22, 2017Aspirant
Same problem. I have to change orbi to AP mode with my existing router. Problem is once I change orbi to AP mode, I can't login to the orbi web login or use IOS app. Netgear need to fix this.
Hansyeung
I just did a firmware upgrade and now I can access Orbi via my iOS.
