herebedragons69
Aug 15, 2019Aspirant
Orbi and Telstra FTTP NBN
Hi Everyone, 1st post. FTW! I want to check the compatibility of the Netgear Orbi AC2200 Tri-band Mesh Router connecting directly to my Telstra FTTP NBN box.
ekhalil
Aug 15, 2019Master
FTTP or FTTH typically uses a Gigabit Ethernet port in the wall or a fiber modem to which you can connect Orbi.
It should be possible to connect Orbi WAN port directly to the NBN modem.
If you will require phone service then I guess you can connect the ISP Gateway to a LAN port on Orbi.
