herebedragons69
Aug 15, 2019Aspirant
Orbi and Telstra FTTP NBN
Hi Everyone, 1st post. FTW! I want to check the compatibility of the Netgear Orbi AC2200 Tri-band Mesh Router connecting directly to my Telstra FTTP NBN box.
Aug 15, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
herebedragons69 wrote:Hi Everyone,1st post. FTW!
herebedragons69
Aug 16, 2019Aspirant
Thanks for the replies everyone. I have something useful from each of your posts.
Currently I have a Telstra branded NEtgear v7610 as my modem / router. Wifi drops out on it all the time, and ithe new Synology Nas I just picked up can't automatically configure all the neccessarry port forwards as my modem is not listed in their automated settings. I'm not keen to manually configure the 30+ ports, so I was looking at different modem and orbi would solve another problem i have with regard to wifi range, plus, it looks cool.
- FURRYe38Aug 16, 2019Guru - Experienced User
IT would be good to get into a stand alone modem if possible to use with Orbi or any external router. Good Luck.
herebedragons69 wrote:Thanks for the replies everyone. I have something useful from each of your posts.
