JoshBear
Jun 22, 2019Aspirant
Orbi and the Arlo Q
Hi All Pls can I have some help. I have an orbi 50 with 6 satellites and all is working very very well (most of the time) with the exception of an arlo Q camera. The camera connects after setup ...
Jun 23, 2019Guru - Experienced User
Sounds like a place to post in the Arlo camera forums since this is a problem with the camera and not the ORbi system:
https://community.arlo.com/t5/Arlo-Forum-Discussions/ct-p/arlo-forum-discussions
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- JoshBearJun 23, 2019Aspirant
Thanks. Will try those things. I do see this as an Orbi issue as the camera works perfectly in the annex which uses a different Wi-fi network.
Regards
josh
