sue-doe-nimm
Jul 14, 2018Aspirant
Orbi and the modem are both running their own networks.
Hi! I have an Orbi mesh network Wi-Fi system set up, connected to a Actiontek Q1000 modem. The Orbi WiFi network is accessible at its network name, "suedoenimm" (the config page is at 192.168.1.1, I ...
Jul 14, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
sue-doe-nimm
FURRYe38 So will that improve the speed of the Orbi network?
- FURRYe38Jul 14, 2018Guru - Experienced User
The less interferences from other wifi sources should help with performances. Other factors may be at play as well, surrounding environment, other wifi neighbors and such.
