iayork
Sep 30, 2018Aspirant
Orbi and vertical signal
I just installed an RBR50 router and satellite to replace the Pace 5268AC AT&T fiber modem. Both router and satellite are on my main floor, and they seem to be doing very well on that floor. But they...
iayork
Oct 07, 2018Aspirant
Appreciate the replies, but none were helpful. My upstairs bedroom signal is still very slow with the Orbi in spite of (1) Great Orbi signal elsewhere in the house and (2) much better wifi signal from the original router in that area.
Oct 07, 2018Guru - Experienced User
Did you teste with just the Orbi router alone while the satellite was turned off?
- iayorkOct 07, 2018Aspirant
I did. It made no difference at all, surprisingly. In any case I have the original wifi turned off now and the signal is still relatively slow in that area only.
