j1n
Mar 15, 2018Apprentice
Orbi and WEP
I’ve been under the assumption that using WPS encryption is insecure, and the best encryption is to use WPA2 (hopefully with the Krack exploit patched). I noticed that it seems the Orbi system does us...
j1n
You are right. I did mix up “WPA” & “WEP” with WPS. Regardless, WPS can be turned on or off on the Orbi outdoor wireless satellite (RBS50Y) for security purposes. I guess that doesn’t make sense with the Orbi Router and indoor satellite(s).
st_shaw
Mar 15, 2018Master
I'm not sure if you have a question anymore, but clearly, WPS should be turned off on an outdoor device.
- larryindublinMar 16, 2018Luminary
st_shawwrote:I'm not sure if you have a question anymore, but clearly, WPS should be turned off on an outdoor device.
I understand what is is saying. The risk of someone just coming up to your outdoor Orbi is you can connect just by pushing a button without knowing the password, so they allow turning WPS totally off. While a little lower risk, it still is there for the indoor units. For example: I have a contractor working on the house. I can CHOOSE to give them guest wifi access but they could also just push the WPS button and get connected to my router.
I agree, that functionality should be able to be totally turned off.
