j1n
Mar 15, 2018Apprentice
Orbi and WEP
I’ve been under the assumption that using WPS encryption is insecure, and the best encryption is to use WPA2 (hopefully with the Krack exploit patched). I noticed that it seems the Orbi system does us...
j1n
Mar 16, 2018Apprentice
“I agree with what you wrote. But, if somoene can touch your Orbi to push the WPS button, they can plug something into a LAN port and access the LAN directly. So, WPS ON or OFF doesn't make a huge difference in security if someone has physical access to your router.”
The Outdoor Orbi does not have any LAN ports, so they added the ability to turn off WPS (sync button) so no one can easily get access to your network. Since the other Orbi satellites have LAN ports, you’re saying that it wouldn’t matter if the WPS (sync) button was disabled or not because they could use a cable to get into your network.
Is the Sync Button (using WPS) only used to sync the router with the satellites, or could someone get wireless access to the network by pressing the sync button?
st_shaw
Mar 16, 2018Master
Makes sense there are no LAN ports on the outside Orbi, because "yes" anyone can access your network if they plug into the LAN. Unless you "Block all new devices" based on MAC addresses.
According to the Orbi User Manual the sync button on the router is used to connect WPS-enabled clients. The satellites are WPS clients, so their WPS button should not allow other clients to join the network.
Since it's a client, it makes no sense that the RBS50Y would allow you to disable WPS. In fact, I don't see anything about disabling WPS in the RBS50Y user manual. Where did you get the information that WPS could be disabled on the RBS50Y?
- j1nMar 28, 2018ApprenticeThe RBS50Y not only lets you disable the Sync (WPS) button, but the online setup manual (screenshot attached), states the physical sync button will automatically be disabled once the outdoor Orbi is synced to your router and Netgear recommends keeping the sync button turned off for security reasons. I was questioning that since I have the ability to turn on/off the physical sync button on the RBS50Y, that I would like to have that ability to turn on/off the Sync button on the router and satellites if I wanted to through the router interface.
- st_shawMar 28, 2018Master
j1n Thanks for the information. I have an RBS50Y arriving Monday.
After reading what you posted, I now see the part about the sync button being disabled in the RBS50Y user manual on page 19.
I checked on my RBR50 and there is no setting to disable sync/ WPS on the indoor RBS50 Orbi satellites, like you can with the outdoor satellite. I guess it's something NETGEAR could probably add, if they wanted to, but chose not to.
