Timnex
Sep 03, 2016Follower
Orbi and xfinity
Can the orbi router and satellite be used with an xfinity wireless modem?
DarrenM
Sep 06, 2016Sr. NETGEAR Moderator
Hello Timnex
Yes orbi can be set as a AP mode and work with other routers.
DarrenM
GeekGear
Oct 01, 2016Guide
You can also ask Comcast to bridge the Wifi network so that there is only one wireless system.
- peteytestingOct 01, 2016Hero
GeekGear wrote:You can also ask Comcast to bridge the Wifi network so that there is only one wireless system.
to be honest with you its not a good idea to run a different transmission with the same ssid name as the orbi system as this will confuse the clients as the orbi system will be trying to steer the clients etc , i would only do this is the primary transmission is well away from the orbi router or sat to avoid wifi confusion and voodoo
pete
- GeekGearOct 01, 2016Guide
I am running only one wireless using one SSID from Orbi. My Xfinity router is not transmitting Wifi because I had it turned off.
hi
good , just pointing out to others as well that its not wise to run the orbi with wifi next to another router with wifi on as well never mind running the same ssid name on both as this would create wifi voodoo :)
