Baxter2020
May 29, 2020Guide
Orbi and Xfinity
I’m looking to add Orbi for a larger home and wanted the latest version. I was thinking of adding to the latest Xfinity Gateway and saw how that is possible, but is there also a new Orbi version that ...
Baxter2020
May 29, 2020Guide
Thanks for replying! So I am clear, you are suggesting dropping the Xfinity gateway so it is a cleaner setup? Is the older Orbi modem compatible with the new models that have been released? If anyone has any recommendations on the right model for Xfinity service, I would greatly appreciate it. Thanks!
May 30, 2020Guru - Experienced User
I just mean running the modem seperate from the router is a good plan.
Something like the CM1000/CM1100 work great with orbi.
