Baxter2020
May 29, 2020Guide
Orbi and Xfinity
I’m looking to add Orbi for a larger home and wanted the latest version. I was thinking of adding to the latest Xfinity Gateway and saw how that is possible, but is there also a new Orbi version that ...
May 30, 2020Guru - Experienced User
There is the NG CAX80 which is NG next gen gateway modem with AX wifi. No release date though.
IF you want AX now, install a CM series modem and get a Orbi AX 7 or 8 series system behind the CM modem.
Baxter2020 wrote:
I’m looking to add Orbi for a larger home and wanted the latest version. I was thinking of adding to the latest Xfinity Gateway and saw how that is possible, but is there also a new Orbi version that includes the modem so I can stop renting from Xfinity? The older model seems backordered everywhere. Is it possible to add an Orbi modem after the fact if I start with the mesh and decide to swap out the Xfinity gateway after the fact? The gateway is their new model - CGM4331COM
