bigfurrymonster
Nov 30, 2020Follower
Orbi AP mode as wifi->Lan adapter
Hi, my internet at home is broken and I m using my smartphone wifi tethering as a backup.
I have a device that can only connect through a lan port.
I d like to setup my Orbi as an AP where the input is a wifi signal from a device connected to the internet and the output is internet on the lan ports.
Is this possible?
I know the default AP mode does the opposite of what I want (lan input from a device with internet to wifi output)
Is this possible?
1 Reply
Is this possible?
I know the default AP mode does the opposite of what I want (lan input from a device with internet to wifi output)You understand correctly. The Orbi, and every other WiFi router I am aware of, is designed to get internet through an ethernet connection, not a WiFi connection.
The only viable solution is to get internet access that provides an ethernet connection, such as an LTE modem, cable modem, fiber ONT, etc.
