Webdad
Jun 13, 2021Aspirant
Orbi App - Something went wrong
I've had an Orbi RBR50 three node system up and running for a while, and have generally used the direct login from a PC web browser for monitoring / maintenance. Today when trying to open the and...
CrimpOn
Jun 13, 2021Guru - Experienced User
"Something went wrong" is not very helpful, is it?
Have you established that the web interface does not contain the information you need?
Netgear provides Armor for both Orbi and Nighthawk product lines, and each has an "app". The Orbi app is the one that works with Orbi routers.
