Dustin_V
May 09, 2018NETGEAR Employee Retired
Orbi App 2.2 is Coming Soon!
We’re always working to improve your Orbi experience. This next release has all the Orbi App features you love and more. Along with performance improvements and bug fixes, of course, we’ve added ...
- Jun 15, 2018
Orbi App 2.2 is now available! Please visit the following thread to join the conversation.
https://community.netgear.com/t5/Orbi/New-Orbi-App-Now-Available/m-p/1591498#M33775
DavidUnboxed
May 14, 2018Star
My RBK50 & RBS50 are working great. The router I replaced was struggling with UPNP to XboxLive when I put two XBONEX's behind it. Generally, I had to restart the router, then each XBONEX daily. The Orbi's have worked so well, I have not had to do that even once since I put them about a week ago - and those critical systems are used daily, right along with my VPN to corporate. :)
I would like to see Firmware QoS or simple device priority but all in all this thing is a vast improvement over my last 5 or 6 routers in the last 10 years. I should get my 2nd RBS50 today. I only need 1 to cover my 2300 Sq ft home if I have my ISP drop central in the home, but I don't. My home office with the ISP drop is one corner, my game room on an adjacent corner, and the 3rd device will go to the far. My hunch is I will get very good yard coverage all around when I add the 3rd, it' bit weak since both existing devices on the front corners and home is narrow but deep. Unlike some, I like the yard coverage - my home is in the middle of 1/3 acre glade on a 5-acre lot. It will be interesting to see if hub or span topology is best.
2XS
May 14, 2018Initiate
ohoh... a 3rd device. That´s where my issues started. Good luck with your setup!:smileyhappy:
- PaulK617May 14, 2018Star
Current firmwarev2.1.4.10
Had my system for about a year. Been losing connection after first 6 months ever since new firmware updates. Just had to reboot my router again just now. I was in the middle of a project. Last month I updated to v2.1.4.10 and that didn't help. Last week had to do a master reset and reconnect all my devices (22 total). That was a pain. If the firmware works correctly, I shouldn't have to do a master reset then update it. Netgear need get their crap together first, instead of trying to be fancy on useless stuff. Alexa could only reboot the router anyway! The orbi app is intuitive but it lags behind the status without auto refresh. Obviously, if the product works good then we won't need a community forum. Less post more happy customers. Focus on reliability and customer satisfaction because in this era there's no loyalty. If your product don't work people will go somewhere else. I'm about fedup with this crap, tinkering with the network takes up a lot time. Get it together Netgear!
- Dustin278May 14, 2018Apprentice
2XS wrote:
I would like to see Firmware QoS or simple device priority but all in all this thing is a vast improvement over my last 5 or 6 routers in the last 10 years. I should get my 2nd RBS50 today. I only need 1 to cover my 2300 Sq ft home if I have my ISP drop central in the home, but I don't. My home office with the ISP drop is one corner, my game room on an adjacent corner, and the 3rd device will go to the far. My hunch is I will get very good yard coverage all around when I add the 3rd, it' bit weak since both existing devices on the front corners and home is narrow but deep. Unlike some, I like the yard coverage - my home is in the middle of 1/3 acre glade on a 5-acre lot. It will be interesting to see if hub or span topology is best.ohoh... a 3rd device. That´s where my issues started. Good luck with your setup!:smileyhappy:
I have 4 total Orbi's - I put my Orbi in AP mode and have 1 Router + 3 Satellites (1 Router RBR50 on main level with 2 - RBS50 Satellite's on my upper level and my basement with 1 small plugin RBS30 in the garage) - probably overkill but has been great for me and covers my whole yard - no issues since the S8 bug was fixed many months ago.
- tsigMay 15, 2018Luminary
I recently added a 2nd satellite to my RBR50. The RBS50 was over a year old and had never been used. The biggest issue I had was having to manually update the firmware, and figuring out how many I could skip. After updating it twice I was finally able to auto update to the latest firmware. Everything has been perfect since. No drama.
- DavidUnboxedMay 15, 2018Star
Setup went well last night. I ran into some issues getting the new RBS50 to connect, which I suspect were due to the firmware version being older, out of box, on this RBS50. I tried setup with both the app and the web portal. Both appeared time timout leaving the device showing as disconnected. I spent about 10 minutes on it, took a look at the manual and did not see how to handle the situation through I did see the advice to always update the satellite first. As I walked away, I pressed the sync button on both my devices (not knowing if that was a supported method, and I planned to come back with a wire just in case I needed to tie them together to get an update on the new RBS50. After dinner, I came back and noted the new device was showing and firmware had been updated. I'm not exactly sure what twiddle I did that allowed it to update, so I recommend some improvement to the manual on how to handle back-level OS on a satellite. While joined and working, and everything right in the app, I noticed the web interface showing saying there was only one satellite in its count, though showing two. I rebooted using the app and that issue went away. That was the first ever reboot after initial setup for the RBK50. The three seem to be playing well. I will let it bake like that, but already see no performance degredation and extended coverage expected. At some point, I will consider switching mesh, beamforming, etc. Right now, I see those were off.
Recommended Feature Add: Have a page that list all the devices in by the technology they are using to connect, with the worst performers up top so that people know better what to replace if any device is forcing the system to hold back to accomodate the ancient devices. ;) - StanfieldMay 15, 2018Initiate
We all know that is where the fun begins. You have problems with 2 devices? Let's add a third and watch them increase exponentially.
I can only run two, which barely cover my 2700 square foot one level house. I'd love to get coverage in all the bedrooms but you'd need a different product for that. One made by another comapny.
You must live in an alternate dimension where the product get's tested and issues are resolved before it is released to paying customers. That must be nice.
- tsigMay 16, 2018Luminary
Or maybe things aren't as bad as the whiners on this site make it out to be.
- DavidUnboxedMay 16, 2018Star
Still no problems with my setup; the 2nd satillite and the original pair are running fine. My ISP experienced an outage last night, but the Orbi stayed up. Unexpected bonus: With my old router, my Google Fi phones saw the wi-fi as up and did not quickly determine that there was no longer an Internet connection, so I had to switch them to data manually. With the Orbi setup, when the ISP failed, not only did the Orbi stay up and running letting my local WAN/LAN work, but Google Fi quickly saw that there was no internet connection through the Wi-Fi and transitioned to Data, and resumed Wi-Fi when the ISP outage resolved. On the other hand, the Orbi app didn't handle the outage well, and would not let me see device status; but I was able to see it from a WAN/LAN connected PC. I look forward to seeing and using the updated app and will have to test and see how it handles if I kill the connection from modem to router :).
- PaulK617May 16, 2018Star
V.2.1.4.10 My router keep dropping connections throughout the day.. I have about 22 wireless devices. Any pros in here that could help me configure my settings? What are some setting will you recommend to enable or disable?
V2.1.4.10 My router keep dropping connections throughout the day.. I have about 22 wireless devices. Any pros in here that could help me configure my settings? What are some setting will you recommend to enable or disable?
- EfrugierMay 18, 2018Tutor
Yes, just had to do a master reset after firmware upgrade. Quite a a pain
