NRO57
Sep 18, 2019Aspirant
Orbi app does not show check for updates button
I need to update by orbi firmware, but the orbi app does not show the check for update button.
Sep 19, 2019Guru - Experienced User
"if it works, don't fix it."
Retired_Member
Sep 19, 2019
FURRYe38 wrote:"if it works, don't fix it."
You stole that from my playbook. For it's not found living on the 'edge'.
- FURRYe38Sep 19, 2019Guru - Experienced User
Okay.
Actually "if it works, don't fix it." has been around for a long time. Any one can use it. Users choice.
- Retired_MemberSep 19, 2019
FURRYe38 wrote:Okay.
Once again you're missing my point. Any one CAN use it, however in this forum the consensus has been to update without any thought to the consequences, rather let me see if this new FW will get me any faster. One person recently said they know what's best for their system. Really? NG has a job for you!
I for one have repeatedly stated that IF your network is working leave it alone. Do you not recall the whinning and complaning about turning off the FW auto updates from NGs end? So in here, in this forum, I feel I have been the only one with this position.
Its only one position. In the end it's up to the user to decide what they want to do with there stuff.
Were just here to help them if something goes wrong.
