NRO57
Sep 18, 2019Aspirant
Orbi app does not show check for updates button
I need to update by orbi firmware, but the orbi app does not show the check for update button.
Retired_Member
Sep 19, 2019
FURRYe38 wrote:"if it works, don't fix it."
You stole that from my playbook. For it's not found living on the 'edge'.
Sep 19, 2019Guru - Experienced User
Okay.
Actually "if it works, don't fix it." has been around for a long time. Any one can use it. Users choice.
- Retired_MemberSep 19, 2019
FURRYe38 wrote:Okay.
Once again you're missing my point. Any one CAN use it, however in this forum the consensus has been to update without any thought to the consequences, rather let me see if this new FW will get me any faster. One person recently said they know what's best for their system. Really? NG has a job for you!
I for one have repeatedly stated that IF your network is working leave it alone. Do you not recall the whinning and complaning about turning off the FW auto updates from NGs end? So in here, in this forum, I feel I have been the only one with this position.
- FURRYe38Sep 19, 2019Guru - Experienced User
Its only one position. In the end it's up to the user to decide what they want to do with there stuff.
Were just here to help them if something goes wrong.
FURRYe38 wrote:Its only one position. In the end it's up to the user to decide what they want to do with there stuff.
You still don't get it....IT should be your first position. Go back and ready all the posts about how folks complained....."Please turn off the auto-update...quit pushing FW on us we don't want." So NG did and now folks are doing what NG did before and that is to update FW all the while their system was working fine and now it doesn't. I even saw a post today were someone said they HAD to update their FW. Really? And to be clear I'm NOT talking about all those problems that seem to appear because of the many ways folks configure their system. I'm talking about the user who thinks he/she HAS to update the FW because they think it will make their system run faster and better not realizing it's fine as it is.
You and other 'helpers' need to mention the leave it alone idea more often. You'll feel better.
