Trusted_Whitey
Jul 20, 2018Aspirant
Orbi App in Access Point Mode
Is it possible to use the Orbi app when the router is just in access point mode and using a non-netgear router? I would just like to be access the Wi-Fi settings
Jul 20, 2018Guru - Experienced User
Yes and the app only supports Orbi systems. For non orbi NG routers, you have to use Genie for those models.
Trusted_Whitey
Thanks for the reply.
Just to be clear and I wouldn't be using any type of netgear router (a draytek in fact) just an Orbi router in access point mode with two other satellites.
I just want to use the Orbi app to access the Wi-Fi settings
- FURRYe38Jul 20, 2018Guru - Experienced User
Should work fine for AP mode.
- ciacciNov 15, 2018AspirantSame question there is a chance to use orbi app in AP mode?
- FURRYe38Nov 15, 2018Guru - Experienced User
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
