Trusted_Whitey
Jul 20, 2018Aspirant
Orbi App in Access Point Mode
Is it possible to use the Orbi app when the router is just in access point mode and using a non-netgear router? I would just like to be access the Wi-Fi settings
Trusted_Whitey
Thanks for the reply.
Just to be clear and I wouldn't be using any type of netgear router (a draytek in fact) just an Orbi router in access point mode with two other satellites.
I just want to use the Orbi app to access the Wi-Fi settings
Jul 20, 2018Guru - Experienced User
Should work fine for AP mode.
- ciacciNov 15, 2018AspirantSame question there is a chance to use orbi app in AP mode?
- FURRYe38Nov 15, 2018Guru - Experienced User
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
ciacci wrote:
Same question there is a chance to use orbi app in AP mode?- ukwildcat4life7Nov 18, 2018Aspirant
If I set up my Orbi router and satellite in access point mode will all the functions of the orbi app ( particularly remote access) still work or will that be disabled while in access point mode? Any input greatly appreciated as I can't find any informaton on this. Thanks
