Trusted_Whitey
Jul 20, 2018Aspirant
Orbi App in Access Point Mode
Is it possible to use the Orbi app when the router is just in access point mode and using a non-netgear router? I would just like to be access the Wi-Fi settings
ciacci
Nov 21, 2018Aspirant
Exactly , the app even if we are under same Wifi is unable to find the router, appear the usual message "issue connecting with..."
consider that also the computer have issue to connect under "orbilogin.com" it works only with exact IP address of the router
I think there is a limit in AP mode that conflict with the app and usual standard addresses
Steven_Belfast
Nov 22, 2018Apprentice
Can you provide more information on your setup,
IP addresses of devices like routers, access points ect.
When setting Orbi in Ap mode did you assign a ip or leave it dynamic ?
