Trusted_Whitey
Jul 20, 2018Aspirant
Orbi App in Access Point Mode
Is it possible to use the Orbi app when the router is just in access point mode and using a non-netgear router? I would just like to be access the Wi-Fi settings
ciacci
Nov 25, 2018Aspirant
Hi sorry but i was forced to switch to router mode due to a fault on the other router... now the mobile app works fine
in any case previous set up was: AP mode - dynamic IP or fixed nothing change - only acces wia web based app with direct IP connection, no chance to use the mobile app
Now switching to router mode the app connect flawlessly
thanks
Nov 26, 2018Guru - Experienced User
Glad it's working. Wonder why it works for others in AP mode and others no so much.
Enjoy, :smileywink:
thanks
