Beav18
Jan 05, 2019Aspirant
Orbi app My Orbi System
In the orbi app menu you can select My Orbi System. When I do it shows my router connected but the satellite says no connected device found. Yet if I go to orbilogin.net it shows the satellite connec...
ekhalil
Jan 05, 2019Master
Please note that -in the Orbi app- you can access the device list either using the "Network Map" or by going to the "Device List", see below:
If select the "Device list" and then when you get the list you pull down the list then the device list will be updated. Have you tried that?
