Beav18
Jan 05, 2019Aspirant
Orbi app My Orbi System
In the orbi app menu you can select My Orbi System. When I do it shows my router connected but the satellite says no connected device found. Yet if I go to orbilogin.net it shows the satellite connec...
TC_in_Montana
Jan 05, 2019Virtuoso
What you are describing means that you have no devices connecting through/to your satellite. They are all connecting through/to the Orbi router instead.
- Beav18Jan 05, 2019AspirantReally? So I guess I’m confused as to whether my satellite is reall connected. The satellite is upstairs and shows connected through orbilogin net but not through the app. I can ping the IP address that orbilogin shows for the satellite and it responds. How can I troubleshoot this. Any way to tell if I’m connected to the satellite or the router
- ekhalilJan 05, 2019Master
Beav18 wrote:
Really? So I guess I’m confused as to whether my satellite is reall connected. The satellite is upstairs and shows connected through orbilogin net but not through the app. I can ping the IP address that orbilogin shows for the satellite and it responds. How can I troubleshoot this. Any way to tell if I’m connected to the satellite or the routerWhere do you see in the app that the satelite is not connected? Do you look in the "Network Map"?
- Beav18Jan 05, 2019AspirantI don’t get a network map option. Mine looks like this and if I get the home icon I get a list and I pick my Orbi network which is where it says not connected
