Beav18
Jan 05, 2019Aspirant
Orbi app My Orbi System
In the orbi app menu you can select My Orbi System. When I do it shows my router connected but the satellite says no connected device found. Yet if I go to orbilogin.net it shows the satellite connec...
Beav18
Really? So I guess I’m confused as to whether my satellite is reall connected. The satellite is upstairs and shows connected through orbilogin net but not through the app. I can ping the IP address that orbilogin shows for the satellite and it responds. How can I troubleshoot this. Any way to tell if I’m connected to the satellite or the router
ekhalil
Jan 05, 2019Master
Where do you see in the app that the satelite is not connected? Do you look in the "Network Map"?
- Beav18Jan 05, 2019AspirantI don’t get a network map option. Mine looks like this and if I get the home icon I get a list and I pick my Orbi network which is where it says not connected
- TC_in_MontanaJan 05, 2019Virtuoso
Interesting that the RBW30 shows OFFLINE. However, your APP main page shows that you have one satellite connected.
So, is the RBW30 the ONLY satellite you have on your system? Or do you have another one?
Sometimes, the APP does not really give a good picture of your connections and devices.
Can I suggest you open up a browser window and connect to your router (usually can do it through 192.168.1.1). I am of course, assuming that you are using the router as a router and not an AP. You will need to provide "Admin" as the User ID, and your Administrator Password as the password to get into the router.
Then click on the Connected Devices icon.
This will show your satellite(s) at the top portion of the screen, and connected devices below it. You can check for the status of the connection of the RBW30 there (it might say Good, Poor, Config Sync, etc).
You can also use that device list to see what the other devices on your network are attached to (router, satellite, etc).
Just the one satellite. It does show connected when I log into the router but I didn’t find where to see how good a connection it was. Also. It shows that nothing is connected to the satellite and the two Amazon devices are upstairs with the satellite.
