MJL316
Dec 31, 2020Initiate
ORBI App not connecting to router
After downloading IOS 14 my Orbi App will not connect to ORBI router, even twith rying anywhere access connection. Keep getting errors that my wifi is off and local area network is off, which is not ...
Honestbridge
Feb 16, 2021Initiate
I’m having the same issue. Just started today after a couple of months owning the new Orbi. Works fine on all of my wifi my phone will just not locate it.
Feb 16, 2021Guru - Experienced User
What FW version is currently loaded?
